Introduction: How to Protect a Padlock
I’d recently added a dead bolt to my workshop for added protection against any would be thieves. But I realised this left the padlock out in the open ripe for being cut with bolt cutters. So I devised a simple and cheap solution to prevent the use of bolt cutters or shims on my padlock.
While I realise this setup is no match for a grinder. It’s designed to act as a deterrent and at very least hopefully slow down anyone trying to break in.
The steps may differ depending on the current setup you have but the basic shape and principles will remain the same.
Step 1: What You Will Need
Materials Needed:
1x Piece of Scrap 1” Square Tube
Tools Needed:
1x Hammer
1x Centre Punch
1x Marker
1x 8mm Drill Bit
1x Grinder
1x Drill
1x Welder
Personal Protective Equipment:
1x Gloves
1x Welding Gloves
1x Welding Mask
1x Ear Muffs
1x Safety Glasses
Step 2: Mark Out Shackle Hole
This part will differ depending on the set up you have. Mark out and centre punch this hole to match your existing lock setup.
Step 3: Measure Shackle Distance
Once the first hole has been marked, measure the distance between the shackle (in this case 25mm) and mark the second hole.
When drilling the first hole (left) using an 8mm drill bit (shackle size), drill through both the top and bottom sides of the square tube. With the second hole (right) using an 8mm drill bit drill through the topside only.
Step 4: Elongate and Cut Hole
Mark out the second hole drilled so it runs all the way to the edge of the steel. Then grind out the area, it should look similar to the picture above.
Step 5: Cut Out Lock Groove
Flip the piece over in the vise and cut in the distance needed to be able to click the lock into place. In this case it was 20mm in. Be sure to cut to the edge of the square tube at the sides.
Step 6: Weld on Shim
Weld a shim (spacer) on what will be the underside hole. The thickness needed will vary depending on the lock used but the idea is to eliminate any up or down movement when the locked it clicked shut. It will also prevent the crucial side of the padlock from being cut with bolt cutters.
Step 7: Final Steps
Now it’s pretty much complete. Give it a paint to prevent rust, check everything fits as it should and that tolerances are tight as this will make it harder for anyone trying to cut through the shackle.
Step 8: Final Words
While this will never stop someone who is determined to break in, it won’t make it easy for them to cut through.
Also make sure tolerances are as tight as you can go the reason has to do with above picture. While there may seem to be “weak spots” as shown above with tight clearance even with these spots cut by bolt cutters the shackle will not be able to pull through due to the top curve. I have tested with an old lock to be sure.
Your hole diameter should be the same as the shackle diameter to avoid any possible slop.
Hope this helps.
