Introduction: Smartphone / Tab Controlled ROBOT ARM !!
Making ROBOT ARMs is very popular and fun among hobbyists,but it's not that easy to control a ROBOT ARM. So today we'll be making a robot arm that can be controlled using just your Android Smartphone or tablet.
Good news is, you just need to program the Arduino, the App is already available to download for free.
Watch the video for full tutorial
Step 1: Parts You'll Need
1. Servo motor 4x (I'm using micro servo Sg90 but any model or size is okay)
you can use upto 5 servo for this robot arm,I've only 4,so I'm using them.
2. sliced piece of Card Board - to make the body.
3. USB OTG (on the go) [pic3 & 4- all the same]
4. And of course a Arduino board (any board)
6. And a few jumpers to make the connection
7. And a 9v battery to power the servo motors.
Buy electronic parts ar utsource.net
Step 2: Making the Robot Arm (THE BODY)
Now in here I'm actually making the body in a way so that I can easily connect and disconnect the ARM anytime. Using some pieces of cardboard and Hot glue I've mounted the Servo motors to the cardboard to make the body. It's better to watch the video to better understand how it's done.
Step 3: Making the GRIPPER (finger for Robot Arm)
I've made the robot gripper using juice straw or pipe. And added a simple fiver or rope so that when it's pulled the grip will be closed .
Step 4: Assemble the Robot ARM
after making the arm and making & the gripper you just assemble the body as shown.
Step 5: The Circuit
Well the circuit is very easy,you just need to power the servo motors. Arduino will take power from your phone via OTG cable. Don't worry, the power consumption is very low.
Step 6: Download the ANDROID APP
Search on google PLAYSTORE - Servo & Esc controller.
Download from here https://play.google.com/store/apps/details?id=com....
Then Install the app.
Step 7: Programming the Arduino
You can get the code from the link in the app, I'm providing the code below
# include <Servo.h> //PWM OUTPUT VARIABLES Servo pin2; Servo pin3; Servo pin4; Servo pin5; Servo pin6; //SERIAL USB BUFFER char inData[ 65 ]; // Allocate some space for the string char inChar; // Where to store the character read byte index = 0 ; // Index into array; where to store the character void setup () { //START PIN OUTPUT pin2. attach ( 2); // attaches the servo on pin 9 to the servo object pin3. attach ( 3); pin4. attach ( 4); pin5. attach ( 5); pin6. attach ( 6); //SEND MINIMAL VAUE 1000, REGUIRED FOR ESC TO ARM (max is 2000) pin2. writeMicroseconds (1000 ); pin3. writeMicroseconds (1000 ); pin4. writeMicroseconds (1000 ); pin5. writeMicroseconds (1000 ); pin6. writeMicroseconds (1000 ); //INIT SERIAL COMMUNICATION WITH ANDROID Serial. begin (115200 ); } void loop () { if (Serial. available () > 0 ){ //WAIT FOR INCOMMING DATA BUFFER TO FILL if (index < 24){ inChar = Serial. read (); // Read a character inData[ index ] = inChar; // Store it index ++; // Increment where to write next if (inChar == 'X' ) index = 0 ; inData[ index ] = '\0' ; // Null terminate the string } } if (index ==24 ){ index = 0; //STRING LOOKS LIKE "A100B96C20D0E" WHERE LETTERS ACT AS DELIMINATOR //STRING CAN CONTAIN SINGLE VALUE LIKE "B96C" String buf = String (inData); int ia = buf. indexOf ( "A", 0); int ib = buf. indexOf ( "B", 0); int ic = buf. indexOf ( "C", 0); int id = buf. indexOf ( "D", 0); int ie = buf. indexOf ( "E", 0); int iff = buf. indexOf ("F" , 0 ); Serial. print ("|" ); //A?B if (ia!=- 1 && ib!=- 1){ //1. CONVERT VALUE TO INTEGER //2. CONVERT 0-100 TO 1000 - 2000 //3. WRITE TO ARDUINO PIN NUMBER 2 pin2. writeMicroseconds (map (buf. substring (ia+ 1, ib). toInt (), 1, 100 , 1000 , 2000 )); //SEND RESPONSE TO ANDROID Serial. print ( "RESPONSE:OK" ); } //B?C if (ib!=- 1 && ic!=- 1){ pin3. writeMicroseconds (map (buf. substring (ib+ 1, ic). toInt (), 1, 100 , 1000 , 2000 )); //Serial.print("PIN3 OK"); } //C?D if (ic!=- 1 && id!=- 1){ pin4. writeMicroseconds (map (buf. substring (ic+ 1, id). toInt (), 1, 100 , 1000 , 2000 )); //Serial.print("PIN4 OK"); } //D?E if (id!=- 1 && ie!=- 1){ pin5. writeMicroseconds (map (buf. substring (id+ 1, ie). toInt (), 1, 100 , 1000 , 2000 )); //Serial.print("PIN5 OK"); } //E?F if (ie!=- 1 && iff!=- 1){ pin5. writeMicroseconds (map (buf. substring (ie+ 1, iff). toInt (), 1 , 100 , 1000 , 2000 )); //Serial.print("PIN6 OK"); } Serial. print ("|00" ); Serial. print ("\n" ); } } void logg (){ }
Step 8: Connect the OTG and Arduino to Phone
Connect the OTG cable to arduino programming (USB B) cable and then connect the wire with the phone. The APP will automatically pop up . Click on 'ok' and twill open. After connecting "port open" message will be seen.
Step 9: Finished
And you're done,just power the Servo and use the app to rotate every single servo of the arm as you please. So Simple.
Thank you.
Please support by subscribing my youTube channel
Make it Move Contest
