Introduction: The Bottlephone:Trash Smartphone Cover
I hear you thinking: this is awesome!
I humbly agree with you. A glamorous smartphone cover, designed to withstand spatter and falls from about the same height you would comfortably drop a naked smartphone. Make your friends jealous, for you are the only one that has a plastic bottle that can SMS, whatsapp, take photo's, internet, MMS (I have never successfully received one) and more!
The Smartbottle has smart-sense technology and enables the user to use their phone through the plastic!
Disclaimer: this may be obvious, but some of the steps may damage your phone if not careful. Phones are not designed to be subjected to large amounts of heat. Also, plastic fumes are toxic. Don't inhale the fumes and conduct this project outside.
That said, please use your brain, it must surely be a better model than mine. So go find that damaged phone and pimp it up!
Step 1: Tools and Materials
- PET bottle (smartphone sized)
- heat gun or hairdryer
- scissors or exacto knife
- smartphone (not your most precious one I suggest)
- coffee (optional but highly suggested, quality tools make for a simpler job)
Step 2: Size Up Your Bottle
I would need to be large enough for obvious reasons.
Step 3: Cut Bottom
Step 4: TAKE OUT YOUR BATTERY!!
before going any further, take out the battery. Melting your phone is a lot more fun when it is not exploding in your face. But the back back.
Step 5: Heat the Plastic
PET bottles shrink when heat is applied. We can use this property to our advantage here. Start at the bottom to enclose the phone and stop it from escaping. Then you can evenly heat the rest to shrink it properly around the phone. Be sure to leave a little room where the buttons go, so these are not pressed by the plastic.
Especially for you kind people at Instructables, I heated my phone up more than I was comfortable with. The phone still works, But I urge you to take pauses and let the phone cool off.
Step 6: Trim
Trim the plastic at the bottom to size so you have a neat Smartbottle, just out of the factory.
Step 7: Reïnsert Battery
Remove bottlecap to push out the phone from the fresh case. Reïnsert the battery and give it a test!
Step 8: Show Off
Show of your rad phone to friends and strangers.
The Bottlephone is suitable for extravagant, strange or otherwise socially nonconform people.
Ideas: Turn the phone upside down in the bottle and seal off with silicone and you (probably) have a waterproof phone. Charging could then happen when the bottle cap is screwed off.
Trash to Treasure
Pocket-Sized Contest
