Introduction: Tin Can Hole Saw
About: Innovative Projects, Diy's, Life Hacks
I needed a large hole saw for one of my projects. I already had a smaller hole saw, therefore I did not want to buy another one....?
You see, a hole saw is not something I use very often. Last time I bought a hole saw for around 10 - 15 USD only to used it once or twice.
I did not want to spend another 15 USD for a tool that will not be used.
In this Instructable, I demonstrate a way to make a hole saw out of a tin can.
It can cut plastic, acrylic and drywall.
Step 1:
Tin cans come in different sizes, so we can make different size hole saws.
First I emptied the can
Step 2:
Then I cut off the inner rim
Step 3:
Then I drilled a hole in the center
Step 4:
I used a rotary tool to cut teeth
Step 5:
I sharpened one end of the bolt
Step 6:
Then I attached it to the can with nuts on both sides
Step 7:
The bottom of the tin can is very thin. I covered it with some hot glue to make it less flexible.
I also covered nuts so they would not come loose
Step 8:
That's it!
Our hole saw is ready!
Before drilling the hole, use a normal drill bit to drill the center hole, so you can insert the bolt.
I tried to cut wood, but it did not work very good. Maybe I had to sharpen the teeth better or the material is too soft for that kind of job.
It's perfect if you need to cut a few holes in materials mentioned above, but you don't want to spend money on a hole saw.
