Introduction: DIY Obstacle Avoiding Robot
This time its a obstacle avoiding robot, which use a ultrasonic sensor , two motors , a motor driver and arduino unoto avoid objects. In this project a servo motor is shown but it is not used.It happens because I didn't find a ultrasonic bracket and I try to make one by my self it was successful but it was programmed to rotate and find the nearest area to go but it didn't rotate properly so I reprogrammed it not to rotate and if it detects a object it must go backwards and turn to right and continue the process. It is not a big problem and you can find a ultrasonic sensor bracket and fix it to the servo motor. I will put both codes, with servo and without servo. And lets make it!!!
Step 1: Things You Need +
Heres the things you needed to make this project.
- Arduino Uno Board + Cable.
- Ultrasonic Sensor HC-SR04.
- Ultrasonic Sensor bracket(I will tell you how to make but you can buy one if you can find).
- H-Bridge L298N Motor driver.
- Bovine wheel.
- Motors with Wheels.
- A plate or something like in the picture.
- 2 9v batteries.
- 2 9v batteries holders.
- A servo motor sg90.(Optional)
- A half breadboard.
- Jumper wires.
- Small cardboard (Optional).
- Cable ties.
Step 2: The Bracket (Optional)
Remember that this is optional and you can always buy a ultrasonic sensor bracket. First take a cardboard and fold it as shown and also fix it as shown and make a hole in the centre.Then fix the the bracket to the servo.
Step 3: Solder the Motors!
Now solder the motors and tape it.
Step 4: Mount All in Place!
Now mount the motors, arduino uno, H-Bridge L298N Motor Driver, Servo motor with Ultrasonic Sensor or only ultrasonic sensor(its optional) and the half breadboard.
Step 5: Connections +
Do all the connections as shown in the picture.
Step 6: Hot Glue and Cable Ties!
Now for the power supply I use a 2 9v batteries. In here we must think far and because of that I hot glue the holders on the motor.And there was a problem in this project. It was that the ultrasonic sensor was folded downwards and it was fixed by hot gluing a small piece of cardboard. Also for the cleanness of the robot I tie all the cables with cable ties.
Step 7: Programming.........
There are 2 types of coding for this robot one is with the servo and without servo. I have use without the servo. But don't worry because I will put both with the servo and without the servo codes. And for both codes you must download the newping library, which you can download from below URL.
https://bitbucket.org/teckel12/arduino-new-ping/do..
You must put the newping library to the libraries folder.
Now heres the code for with the servo.
#include <Servo.h> //Servo motor library. This is standard library
#include <NewPing.h> //Ultrasonic sensor function library. You must install this library//our L298N control pins const int LeftMotorForward = 7; const int LeftMotorBackward = 6; const int RightMotorForward = 4; const int RightMotorBackward = 5;
//sensor pins #define trig_pin A1 //analog input 1 #define echo_pin A2 //analog input 2
#define maximum_distance 200 boolean goesForward = false; int distance = 100;
NewPing sonar(trig_pin, echo_pin, maximum_distance); //sensor function Servo servo_motor; //our servo name
void setup(){
pinMode(RightMotorForward, OUTPUT); pinMode(LeftMotorForward, OUTPUT); pinMode(LeftMotorBackward, OUTPUT); pinMode(RightMotorBackward, OUTPUT); servo_motor.attach(10); //our servo pin
servo_motor.write(115); delay(2000); distance = readPing(); delay(100); distance = readPing(); delay(100); distance = readPing(); delay(100); distance = readPing(); delay(100); }
void loop(){
int distanceRight = 0; int distanceLeft = 0; delay(50);
if (distance <= 20){ moveStop(); delay(300); moveBackward(); delay(400); moveStop(); delay(300); distanceRight = lookRight(); delay(300); distanceLeft = lookLeft(); delay(300);
if (distance >= distanceLeft){ turnRight(); moveStop(); } else{ turnLeft(); moveStop(); } } else{ moveForward(); } distance = readPing(); }
int lookRight(){ servo_motor.write(50); delay(500); int distance = readPing(); delay(100); servo_motor.write(115); return distance; }
int lookLeft(){ servo_motor.write(170); delay(500); int distance = readPing(); delay(100); servo_motor.write(115); return distance; delay(100); }
int readPing(){ delay(70); int cm = sonar.ping_cm(); if (cm==0){ cm=250; } return cm; }
void moveStop(){ digitalWrite(RightMotorForward, LOW); digitalWrite(LeftMotorForward, LOW); digitalWrite(RightMotorBackward, LOW); digitalWrite(LeftMotorBackward, LOW); }
void moveForward(){
if(!goesForward){
goesForward=true; digitalWrite(LeftMotorForward, HIGH); digitalWrite(RightMotorForward, HIGH); digitalWrite(LeftMotorBackward, LOW); digitalWrite(RightMotorBackward, LOW); } }
void moveBackward(){
goesForward=false;
digitalWrite(LeftMotorBackward, HIGH); digitalWrite(RightMotorBackward, HIGH); digitalWrite(LeftMotorForward, LOW); digitalWrite(RightMotorForward, LOW); }
void turnRight(){
digitalWrite(LeftMotorForward, HIGH); digitalWrite(RightMotorBackward, HIGH); digitalWrite(LeftMotorBackward, LOW); digitalWrite(RightMotorForward, LOW); delay(500); digitalWrite(LeftMotorForward, HIGH); digitalWrite(RightMotorForward, HIGH); digitalWrite(LeftMotorBackward, LOW); digitalWrite(RightMotorBackward, LOW); }
void turnLeft(){
digitalWrite(LeftMotorBackward, HIGH); digitalWrite(RightMotorForward, HIGH); digitalWrite(LeftMotorForward, LOW); digitalWrite(RightMotorBackward, LOW);
And here's the code for without the servo.
//our L298N control pins const int LeftMotorForward = 7; const int LeftMotorBackward = 6; const int RightMotorForward = 5; const int RightMotorBackward = 4;
void setup(){
pinMode(RightMotorForward, OUTPUT); pinMode(LeftMotorForward, OUTPUT); pinMode(LeftMotorBackward, OUTPUT); pinMode(RightMotorBackward, OUTPUT); }
void loop(){
void moveForward(){
if(!goesForward){
goesForward=false;
void turnRight(){
void turnLeft(){
Step 8: Done!!!
And our project is done I wish you very good luck on making a Obstacle Avoiding Robot.
And don't forget to vote me!!?????????
Wheels Contest 2017
Arduino Contest 2017
Design For Kids Challenge
